Электрические характеристики |
Наименование | IH | IT | Vmax | Imax | Ttrip | Pdtyp | Rmin | Rmax | R1max | |
А | А | В | А | А | Время(сек) | Вт | Ом | Ом | Ом | |
LP-SM030 | 0.30 | 0.60 | 60 | 10 | 1.5 | 4.0 | 1.9 | 0.700 | 1.300 | 4.800 |
LP-SM050/60 | 0.50 | 1.00 | 60 | 10 | 2.5 | 4.0 | 1.9 | 0.350 | 1.600 | 1.400 |
LP-SM050/30 | 0.50 | 1.00 | 30 | 10 | 2.5 | 4.0 | 1.9 | 0.350 | 1.600 | 1.400 |
LP-SM075 | 0.75 | 1.50 | 30 | 40 | 8.0 | 3.0 | 1.9 | 0.290 | 1.400 | 1.000 |
LP-SM110/33 | 1.10 | 2.20 | 33 | 40 | 8.0 | 2.0 | 1.9 | 0.100 | 0.190 | 0.480 |
LP-SM110/24 | 1.10 | 2.20 | 24 | 40 | 8.0 | 2.0 | 1.9 | 0.100 | 0.190 | 0.480 |
LP-SM110/15 | 1.10 | 2.20 | 15 | 40 | 8.0 | 2.0 | 1.9 | 0.100 | 0.190 | 0.480 |
LP-SM125 | 1.25 | 2.50 | 15 | 40 | 8.0 | 2.0 | 1.6 | 0.070 | 0.120 | 0.250 |
LP-SM130/33 | 1.30 | 2.60 | 33 | 40 | 8.0 | 4.0 | 2.1 | 0.080 | 0.130 | 0.280 |
LP-SM130/15 | 1.30 | 2.60 | 15 | 40 | 8.0 | 4.0 | 2.1 | 0.080 | 0.130 | 0.280 |
LP-SM150/33 | 1.50 | 3.00 | 33 | 40 | 8.0 | 5.0 | 2.1 | 0.060 | 0.110 | 0.250 |
LP-SM150/15 | 1.50 | 3.00 | 15 | 40 | 8.0 | 5.0 | 2.1 | 0.060 | 0.110 | 0.250 |
LP-SM185 | 1.85 | 3.70 | 15 | 40 | 8.0 | 5.0 | 2.1 | 0.045 | 0.080 | 0.165 |
LP-SM200 | 2.00 | 4.00 | 15 | 40 | 8.0 | 12.0 | 2.1 | 0.045 | 0.065 | 0.125 |
LP-SM250 | 2.50 | 5.00 | 15 | 40 | 8.0 | 25.0 | 1.9 | 0.025 | 0.052 | 0.085 |
LP-SM260 | 2.60 | 5.20 | 6 | 40 | 8.0 | 20.0 | 1.9 | 0.025 | 0.052 | 0.075 |
LP-SM300 | 3.00 | 6.00 | 6 | 40 | 8.0 | 35.0 | 1.9 | 0.015 | 0.033 | 0.480 |
Габаритные размеры, мм
Корпус |
Наименование | A | B | C | D |
Max. | Max. | Max. | Max. | |
LP-SM030 | 7.98 | 3.18 | 5.44 | 0.70 |
LP-SM050/60 | 7.98 | 3.18 | 5.44 | 0.70 |
LP-SM050/30 | 7.98 | 3.18 | 5.44 | 0.70 |
LP-SM075 | 7.98 | 3.18 | 5.44 | 0.70 |
LP-SM110/33 | 7.98 | 3.00 | 5.44 | 0.70 |
LP-SM110/24 | 7.98 | 3.00 | 5.44 | 0.70 |
LP-SM110/15 | 7.98 | 3.00 | 5.44 | 0.70 |
LP-SM125 | 7.98 | 3.00 | 5.00 | 0.70 |
LP-SM130/33 | 9.50 | 3.00 | 6.71 | 0.70 |
LP-SM130/15 | 9.50 | 3.00 | 6.71 | 0.70 |
LP-SM150/33 | 9.50 | 3.00 | 6.71 | 0.70 |
LP-SM150/15 | 9.50 | 3.00 | 6.71 | 0.70 |
LP-SM185 | 9.50 | 3.00 | 6.71 | 0.70 |
LP-SM200 | 9.50 | 3.00 | 6.71 | 0.70 |
LP-SM250 | 9.50 | 3.00 | 6.71 | 0.70 |
LP-SM260 | 7.98 | 3.18 | 5.44 | 0.70 |
LP-SM300 | 7.98 | 3.18 | 5.44 | 0.70 |
Процедура испытания и требования
Испытание | Условия испытания | Отклонения |
Сопротивление | Температура окружающей среды 25oC | Rmin<R<Rmax |
Время размыкания | 5 time IH, Vmax, 25oC | T<max. Время размыкания ( Ttrip ) |
Блокирующий ток | 30 мин, при IH | Без срабатывания |
Количество циклов срабатывания | Vmax, Imax, 100 циклов | Без образования дуги или горения |
Выносливость | Vmax, 24 часа | Без образования дуги или горения |
Габаритный чертеж посадочных мест, мм
Габаритный чертеж посадочных мест |
мм | мм | мм | |
LP-SM030 | 3.1 | 2.3 | 9.7 |
LP-SM050 | 3.1 | 2.3 | 9.7 |
LP-SM075 | 3.1 | 2.3 | 9.7 |
LP-SM110 | 3.1 | 2.3 | 9.7 |
LP-SM125 | 3.1 | 2.3 | 9.7 |
LP-SM130 | 4.6 | 2.3 | 10.7 |
LP-SM150 | 4.6 | 2.3 | 10.7 |
LP-SM185 | 4.6 | 2.3 | 10.7 |
LP-SM200 | 4.6 | 2.3 | 10.7 |
LP-SM250 | 4.6 | 2.3 | 10.7 |
LP-SM260 | 3.1 | 2.3 | 9.7 |
LP-SM300 | 3.1 | 2.3 | 9.7 |
