Расширен перечень микросхем для ремонта РЭА.
22 января 2014 г.
 В продаже новые позиции:
Код товара Наименование Описание Производитель Корпус
135162 ST8024CD smartcard интерфейс ST SO28
146238 FAN7930B CRM mode PFC controller FSC SO8
157176 OB2269AP highly integrated current mode PWM control IC On-Bright DIP8
157177 MP1495DJ (ACS)   MPS
157179 MP1497DJ (ACQ)   MPS
157180 KB4317GRE (ZL54)
157181 LD7750RGR   LD
157183 LD7750GS   LD
157185 LD7576PS   LD SO8
157186 TDA8932BTW Class D audio Amplifier NXP HTSSOP32
157187 SSC2S110
157188 MR4710   SHIN
157189 MP1482DN   MPS
157191 RT8296AHGSP   RICH
157193 PT2323 6-Channel Audio Selector Utilizing CMOS Technology PTC DIP28
157194 NCP1216AP-65   ONS DIP8
157195 MAP3204 Boost type 4 channel LED driver optimized for mid and large size LCD panel backlighting MAP
157196 NCP1237AD-65 (37A65)   ONS
157197 MP3302DJ (N6)   MPS
157199 PS232S 6-Channel secondary monitoring system SiTI SO20
157200 MAX9667ETP+ 10-Channel, 10-Bit, Nonvolatile Programmable Gamma and VCOM Reference Voltages MAX TQFN20
157201 AM5898N Motor Driver for Portable DVD player with DC-DC Step Down Converter Amtek HSOP34
157202 PS229 4-Channel secondary monitoring system SiTI DIP14
157203 YDA164B DIGITAL INPUT STEREO 20W DIGITAL AUDIO POWER AMPLIFIER YAM QFN32
157205 FSBH0170 Green Mode Fairchild Power Switch (FPS) FSC1 DIP8
157206 SLC5012M     SO20
157207 CM6802IP NO BLEED RESISTOR GREEN MODE PFC/PWM CONTROLLER COMBO Champ DIP16
157208 AOZ1051PI EZBuck™ 3 A Synchronous Buck Regulator A&O SO8EP
157209 LNK574DG Zero No-Load Consumption Integrated Off-Line Switcher PWR SO8
157210 OZ9967SN   O2Micro
157211 TOP253PN ШИМ-контроллер Off-line PWM switch, 11 - 16 W PWR DIP8
157212 NCP1397BG High Performance Resonant Mode Controller With Integrated High Voltage Drivers ONS SO16
157213 OZ9970GN   O2Micro
157214 FSL106HR Green Mode Fairchild Power Switch (FPS™) FSC1
157215 STRY6456   SANKEN
157216 RT8901GSC   RICH
157217 SEM3040   .
157218 UBA2014T 600 V driver IC for HF fluorescent lamps NXP SO16
157219 LM4863MT Dual 2.2W Audio Amplifier Plus Stereo Headphone Function NSC1
Полный перечень микросхем для ремонта здесь
